Frames Per Second
DK
Frames Per Second
Post by DK »
Hi.
Am I doing something wrong here? I made an animated sequence set to 25 fps and have been asked by the editor to export it at 50 fps. I reset Moho's frame rate to 50 fps and noticed the audio track is double the size but the animation remains at half that. Is there a way to also scale the animation up automatically to 50fps or do I need to re-scale all the key-frames and project using the menu tools?
Cheers
D.K
Re: Frames Per Second
Unless the animation is meant to end in a high FPS game there's no need for 50 FPS.
Yes, best option is the re-scaling command in the menu.
DK
Post by DK »
Our editor wants the ability to slow down the animation if need be. (PITA but you can't argue with the editor :)
Thanks for the reply slow as I thought I will have to re-scale the key-frames.
Cheers
D.K
