Importing .obj files with colour and texture
Mattyj
Post by Mattyj »
Just wondering how you import a .obj file while retaining the colour and texture that are also within the same folder but look to be separate from the .obj?
SimplSam
Re: Importing .obj files with colour and texture
Post by SimplSam »
For reference .OBJs get info about their material & color from associated .MTL files - which are typically in the same folder, but do not have to be. The .mtl files are listed within the .obj file. Both .obj and .mtl files are plain text / viewable / editable.
Within the .obj you can check for references to material files (.mtl), and similar check the .mtl files for references to image textures. If any paths are incorrect - fix them and save. Or make them local to same directory (i.e. have no path) - and put all relevant files in the same location. Moho should then load the textures OK.
