SS - Number Sequence
SimplSam
Post by SimplSam »
Quickly create animated number sequences
(An update to the built-in number sequence menu script)
Enhanced Features:
+ Specify Start and End of sequence
+ Starts from current frame
+ Specify Count and/or Frame Interval
+ Forward or Reverse numbers (Low-to-High, High-to-Low)
+ Option to Display leading zeros
+ Sequence is created in a Switch Layer
Latest release: https://mohoscripts.com/script/ss_number_sequence
Re: SS - Number Sequence
Nice!
For number counters, I always imported an image sequence I created in my compositing program. That works but if I need to change it, I need to go back to my compositing program and create a variation. SS - Number Sequence should make these extra steps unnecessary.
Will give it a try tonight! Thanks for creating and sharing another useful tool SimplSam. :D
DK
Post by DK »
Another useful enhancement to Moho that should be integrated into the next release.
Thank you so much.
Cheers
D.K
DK
Post by DK »
Hi SimpleSam.
Just to let you know it is working great except for one thing...I selected "leading zero's" but
the script doesn't generate them. It shows them in the display area but doesn't add them to
the final readout.
Cheers
D.K
SimplSam
Post by SimplSam »
DK wrote: Thu Jul 13, 2023 4:05 pm ...I selected "leading zero's" but the script doesn't generate them. It shows them in the display area but doesn't add them to the final readout.
What are your number ranges? It takes the max number of digits in the sequence and makes all numbers that wide by padding with leading zeros - if necessary.
i.e.
10 - 54 you will not see leading zeros
2 - 16 you will (02 ... 09)
80 - 120 you will (080 .. 099)
101 - 999 you will not
DK
Post by DK »
Ahhh...that makes sense. I was just testing it with small ranges 1-20 etc.
Thanks for the explanation and also the fantastic improvement SimpleSam!!!
Double Cheers :D
D.K
