I am running Moho Pro. Is there a way that I can check to see if a puppet that I am building is compatible with Moho Debut?
(Even though I run Moho Pro - there is a possibility that that puppet might, in the future, need to be used by someone who uses Debut.)
Checking Debut Compatibility from Pro?
RedAngelSophia
Re: Checking Debut Compatibility from Pro?
You can switch your Pro version to run as Debut by selecting: Edit > Preferences > ☒ Run as Moho Debut, and then restarting Moho. Then do the opposite to return to Pro.
- hayasidist
If you run Debut it will load and run moho files with most (all???) Pro features. What you can't do is access tools / settings that are Pro only from the UI.
e.g. smart mesh is used in the Kukulkan character (library Moho 12) and you can manually edit the mesh (Transform Point tool) but I think you can't create or assign a warp mesh from the Debut UI.
so it depends on what you mean by
Minor / inconsequential mods - or just "run as is" -- no worries; major re-architecting -- probably hard / impractical to do.RedAngelSophia wrote: ↑Mon Jul 10, 2023 9:50 pm that puppet might, in the future, need to be used by someone who uses Debut.
RedAngelSophia
Thank you very much, both of you!!! I have not yet had a chance to try what you suggested - but I plan to do so —- and I expect that it can solve a great problem.
