How to UNfollow path?
mmmaarten
Post by mmmaarten »
I am animating a mesh over a path and am still tweaking the resolution of the mesh to do so.
So I use follow path to see if its resolution is high enough and than undo the follow path to add more 'vertices'/points to scale up the resolution.
However, I have too little undo points to go back to the state before follow path was applied.
How can we un-follow-path?
BTW Is there a way to automatically scale up the resolution of the mesh (something like what subdivision is in Blender; so add vertices inbetween other vertices to scale resolution up)?
Thanks in advance!
Adults should play more often
Re: How to UNfollow path?
mmmaarten wrote: Wed Jul 05, 2023 12:00 am How can we un-follow-path?
activate the follow path tool with the layer that is following a path active. Click anywhere away from a path.
mmmaarten wrote: Wed Jul 05, 2023 12:00 am BTW Is there a way to automatically scale up the resolution of the mesh (something like what subdivision is in Blender; so add vertices inbetween other vertices to scale resolution up)?
Scripts / Draw / Split Curve
mmmaarten
Post by mmmaarten »
hayasidist wrote: Wed Jul 05, 2023 12:58 am activate the follow path tool with the layer that is following a path active. Click anywhere away from a path.
Ah, that makes sense!
hayasidist wrote: Wed Jul 05, 2023 12:58 am Scripts / Draw / Split Curve
Cool! That's exactly what I needed!
Thanks for your quick and helpful response!
