Moho 13.5.5 Bugs?
- digitalhyper
Moho 13.5.5 Bugs?
Has anyone else had issues with the Motion Graph not allowing you to double click the translations so you can modify the curves? I've tried it on my Cintiq and on my desktop with the mouse. It worked at one point.. but not sure if that was a prior version. However I'm working in Windows 10 with the latest version of Moho Pro. My machine handles Moho just fine. My specs are intel Core i7-7820X 3.6GHz, 64 GB ram, Nvidia 4080 card.. so no problems performance wise.. just seems like overall the timeline stuff is becoming a problem. I notice delays sometimes when trying to move the timeline like it's not reacting to the mouse. Having a hard time even selecting the keyframes it makes on Frame 0 when keyframing. But if I do a select around my keyframes say on frame 6 and drag to frame 0.. it'll select them. Just seems like there may be some bugs with Version 13.5.5 Build 20220524.. Anyone else experiencing this?
Jamie Byers Animation Generalist
http://www.digitalhyper.com
Windows 11 PRO 64 bit
12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz, 128 GB Ram, Nvidia GeForce RTX 4070 & RTX 4080, Wacom Cintiq 16 with Loupedeck Live
Moho Pro 14
After Effects, Premier, Illustrator, Photoshop, 3DS Max, Mudbox and Mocha Pro
Moho Pro 14
Re: Moho 13.5.5 Bugs?
So I think this is something that has been mentioned before - and would be described as a GUI buglet.
In some circumstances I believe the Tools panel is somehow slightly obscuring the timeline, even though it may not look like it.
To address this - decrease/increase the height of the Timeline panel, and the issue should correct itself, and allow you to click controls & keyframes close to frame 0.
- digitalhyper
SimplSam.. Thanks!! That worked.
Moho Pro 14
Moho Pro 14
