calculating point or shape real position
Jasim
Post by Jasim »
Hi :D
I am new to Moho scripting
I am trying to get the real or world position of a selected shape, I use layer position and see if the layer is flipped but my main problem is how to calculate the origin
if the origin is (0,0) then the results are fine else I get strange results sometimes outside the composition dimensions :lol:
        flipH=moho.layer.fFlipH.value
        flipV=moho.layer.fFlipV.value
        LayerxPos=moho.layer.fTranslation.value.x
        LayeryPos=moho.layer.fTranslation.value.y
        Centerx = moho:Mesh():SelectedCenter().x
        Centery = moho:Mesh():SelectedCenter().y
        if flipH == true then
            Centerx =(Centerx-LayerxPos)*-1
            print ("flipped x")
        else
            Centerx =Centerx+LayerxPos
        end
        if flipV == true then
            Centery =(Centery-LayeryPos)*-1
            print ("flipped y")
        else
            Centery =Centery+LayeryPos
        end
Re: calculating point or shape real position
take a look at the bakeVector() function in this: https://www.mediafire.com/file/ob4vvnin ... e.zip/file
that will help you understand some of the transforms that change the stored vector fPos (same applies to the SelectedCenter vector you're working with) to be the visual "on screen" vector position in a vector layer that hasn't been moved / rotated etc.
hope that helps
Jasim
Post by Jasim »
Thank You 😍😍😍
it took me a lot to understand 😂
You are a Genius!
