jump from frame 0 to frame 1
Gakk42
Post by Gakk42 »
https://streamable.com/m5go4d
The eye brows just leap when i go to frame 1. Why is that happening?
Lukas
Re: jump from frame 0 to frame 1
Post by Lukas »
Does it still pop after you clear all animation from the document?
Menu > Animation > Clear Animation > From Document
If the eyebrow now doesn't plop anymore from 0 to 1, you know it's simply animated that way. Remember, everything tweens from frame 0, even if there's no key on frame 1, it might be on it's way to a key farther away.
If the jump is still there after clearing animation from the document, you know it's a problem with how your smartbones are set up.
When you create a smartbone, sometimes your smart action contains a frame where your smartbone is on its design angle (its initial angle, the same it has on frame 0). If this is the case, you need to be sure that the keyframes of every other animated element in that frame are a replica of how they are on frame 0, otherwise you are giving moho two different orders for the same smartbone angle and the consecuence usually looks like what it's happening to your project: smartbones are inactive on frame 0, but when you move to frame 1 they activate the keyframes they have for their current angle value.
Hoptoad
Post by Hoptoad »
I make the same mistake from time to time. If I recall correctly, this is the fix. . .
Go into the smart bone action -- the exact action that is the reason why something is now moving on frame 1.
Copy the keyframes on frame 0 to frame 1.
If that's not the answer, it's pretty close.
If the problem is what I mentioned, then the solution would be to copy the keyframes from frame 0 and paste them in the frame of the smartaction where the smartbone is on its default angle. Sometimes, for those smartbone dials with double direction, the smartbone goes through its default angle arround the middle of the smartaction.
