Hello, A small intruder line in the render
Hernan Gallo
Post by Hernan Gallo »
Hello everyone, I'm Hernán Gallo an illustrator from Mexico, and i learnig Moho by my own :p
A have a problem with a small line that appears in the render from pre-visualization.
When I work whit the vectors it doesn't appear, I use the Hide Edge tool.
Is this a real problem or is normal? and it is a problem, does anyone have the solution?
sorry for the bad English u_u.
Thank you!
Re: Hello, A small intruder line in the render
Hi Hernan,
That's very strange. If the line segment is hidden using the Hide Edge tool, it should not render like that.
Maybe there's a copy of the shape underneath? Shapes can share paths with other shapes so I'm wondering if we are seeing a stroked line that's a slightly different color from the fur.
That said, if Hide Edge was used on the segments, all the stacked shapes should be hidden, so I'm not sure about that.
Just to be sure, is what we're seeing above an actual rendered frame or is it a display preview?
yeah that is strange. Could be that you have some shadow effect in that style, shape or layer? Because the line looks like the same color but shadowed, and maybe the shadow is only visible in that part because it is thin and the black outlike of the rest of the drawing doesn't let us see any shadowing.
Hernan Gallo
Hello Friends, thank you!
Yeah that image was a final render and apears the tiny outline. But in fact, yeah, it vector contains a efect in it, I eliminated all the infromation color in the vector with the Delete Shape tool, and later add the colors again from cero, and the line disapears! :)
Gracias!
Thanks for following up...that's good to know! :D
