Render Style - Customisable with scripts?
Pierre Gombaud
Post by Pierre Gombaud »
Hi, I was thinking about the 'Render Style' part located in the Project Settings window
It is a nice feature, albeit maybe a bit too limited, in the sense the user doesn't have much control over it, as only some kind of presets are available
So, in some cases it works but most of the time the result is not exactly what is expected, because there is no way to fine tune the render settings
So my question would be: is it possible add more flexibility to these presets?
For instance, a script allowing to edit in details these settings so if the Stroke Style is set to 'Sketchy', the user could also control the width of these sketchy strokes or how many lines there is, and so on
Ideally, I wish for something similar to what Poser Pro offered back then, with the 'Sketch Designer' but I guess I'm overly optimistic here:
