Can't install more scripts - Moho does not see them
zorgrian
Post by zorgrian »
Moho won't see the scripts that I put in any folder that I create under /program files/ moho/ scripts
Also, which is weird, I get an 'Access Denied message' when I try to look in the directory using explorer!
The folders under /Program files are all set to read only by default. However I was not aware of any special level of file protection or permission granting mechanism in windows. There are no other options that I can set from the properties dialogue box. does anyone know the answer to this?
What the hell is happening?
myles
Post by myles »
Create a subfolder under "C:\Program Files\Moho\scripts\menu", or use one of the existing subfolders i.e. it has to go under the "menu" subfolder.
Yes, I see the read-only attribute too. Windows weirdness.
I assume it's to stop normal users mucking up installed software, as normal users can't usually install software, only Power Users and Administrators.
What sort of user are you running as? User, Power User, Administrator?
What sort of user did you install Moho as? The same user?
Has your user type been changed recently?
Regards, Myles.
-- Groucho Marx
