MR Path 1.4.2 (Update 31.05.2024)
KuzKuz
Post by KuzKuz »
This script will help you analyze your animation. It draw the trajectories of bones and points over all layers, allowing you to check arcs and spacing.
If you find my script interesting for you I would be happy if you share your feedback.
Version 1.2
Added the ability to use the script in a floating panel.
Version 1.3 New Features:
1. All information about paths and their targets is now stored in the Moho project, allowing you to switch freely between projects without needing to reassign targets each time.
2. It is now possible to track both the base and the tip of a bone simultaneously.
3. Updated the 'Target Manager' window which now always generates random saturated colors.
4. Added color randomization buttons for each target individually. Alt + Click to randomize brightness.
5. Added 'Auto randomize color' option.
Version 1.4 New Features:
1. Updated the Target Manager window, allowing individual targets to be enabled and disabled without removing them from the list.
2. In the Target Manager window, targets are now labeled with bone names instead of their IDs.
3. Bug fixes.
Download link - https://mohoscripts.com/script/mr_path
Re: MR Path 1.0 BETA
MR Path looks very interesting Eugene! There are times when I'm working on FX elements in Moho and wish I could see that path for point animation, and this looks like it will fill that need. I'll give it a try this evening.
As always, thanks for sharing you're cool and very useful tools! :D
KuzKuz
Post by KuzKuz »
Thanks! Fixed several bugs, the link remains the same.
mohgirl
Post by mohgirl »
nice
KuzKuz
Post by KuzKuz »
I've corrected the path-drawing algorithm.
Also, the script should no longer confuse bones that have been added to the tracking list after an Undo operation.
The link remains the same.
KuzKuz
Re: MR Path 1.0
Post by KuzKuz »
Version 1.0 has been released. Video and link in the first post.
KuzKuz
Re: MR Path 1.2
Post by KuzKuz »
Version 1.2 Added the ability to use the script in a floating panel.
KuzKuz
Re: MR Path 1.3 (Update 05.05.2024)
Post by KuzKuz »
MR Path version 1.3
New Features:
mohgirl
Post by mohgirl »
thanks
KuzKuz
Re: MR Path 1.4 (Update 29.05.2024)
Post by KuzKuz »
3. Bug fixes.
KuzKuz
Re: MR Path 1.4.2 (Update 31.05.2024)
Post by KuzKuz »
Version 1.4.2 Bug fixing
mohgirl
Post by mohgirl »
thanks
