add shapes in the middle of animation
jonathan.reaux
Post by jonathan.reaux »
It would be a game changer to be able to add new shapes while animating. Sometimes, while we are working on a shot, we want to throw in a new hand pose, just for that shot on a certain movement. It's really time consuming to have to go back to frame 0 and create the shape, without being able to create that shape based on the action pose in the middle of the animation. To work around it, we've had to take a screen shot of the action pose, then import that screen shot so we can use it as a reference on frame 0. A very slow process.
Re: add shapes in the middle of animation
?? which version are you on?? 13.5.5 draws on frame 0 wherever you are in the timeline.
SimplSam
Post by SimplSam »
I think you just need to disable/uncheck "Enable drawing tools only on frame 0" (as below) - then you can draw at any frame.
I think the main difference in 13.5.5 when the Draw Only In Frame 0 option is disabled is that the shapes are visible from frame 0 up to the frame you're drawing into. In previous versions of Moho, the shape styles are transparent at frame 0 and become visible only at the frame your are drawing into.
In earlier versions, this has has always been a little weird to me and I always wound up copying the style keys from the later frame to frame 0, and then using Layer visibility if I needed to, but these extra steps are no longer necessary in 13.5.5.
Also, I think in 13.5.5 this option is disabled by default so you can draw on any frame (I'm not 100% sure about this.)
Note: Traditionally, I kept this option enabled until I really needed to draw into a later frame, and then I disabled it when I was done...but maybe this isn't so critical now? Hmm. I'll have to think about that.
jonathan.reaux
what?? That is awesome! I had no idea about that option in the tools menu. That will help so much! Thanks.
I should mention one more thing: Even though the drawing is created at both frame 0 and the later frame, any edits you make to the shapes in the later frame will only occur in that frame, so you will see animation from frame 0 to your later frame. But if you draw a new shape in that same layer at the later frame, the same shape will appear in frame 0 along with the previously drawn shapes. In other words, it's only additional keyframe changes you make at the later frame that don't get sent to frame 0.
Just something to be aware of.
