Hello,
I did easy cycle animation, 36 frames. Export mp4 about 2 sec. BUT: I need video with infinity loop or video with for ex. 20 cycles.
Is it possible in MOHO?
Thanks
Olga
Loop animation: export
- Víctor Paredes
Re: Loop animation: export
Hello, Olga.
I think there are at leat three options for what you want:
- Export your 36 frames animation as an animated gif. By default, the gif will loop forever.
- If you want to loop an exported video indefinitely, you can export the 36 frames as a video and setup your video player to loop it (most software give you that option)
- If you want a longer video in which your animation be repeated 20 times, use the Cycle interpolation on the last keyframes of your animation. Then extend the animation to 720 frames (maybe 719, since frames 1 and 720 should be the same) and export it as a video.
That will make your animation to be repeated 20 times in that video.
I hope this helps.
I hope this helps.
