Do not use nested structures for mask layers
ilvmgct
Post by ilvmgct »
It is recommended to use lines to represent each other's affiliation, similar to the Adobe AE layer, to avoid functional issues within and outside the group.
Re: Do not use a nested layer structure for the mask layer.
Yup i second this. That's one huge advantage of a node based workflow or how AE is doing it. It doesn't really matter where the layer is, as long as you define it as a mask to another layer it's fine. All the unnecessary groups i end up with just to mask some things off...
You could just do it as a drop down in the Layer settings à la: Use this layer as Mask, Inversed Mask. If a group is selected, it will use the whole content of the group.
