Time-saving Moho tips
Hoptoad
Post by Hoptoad »
:idea: If you hold down the ALT key while using the Manipulate Bones tool, the tool acts like the Transform Bone tool and only rotates 1 bone. You don't need to switch to the Transform Bone tool when you only want to rotate 1 bone.
:idea: Command+F for Mac or Control+F for Windows is useful for freezing bones, but if you are on a vector layer, command/control+F freezes all the points - point motion and curvature. The usual, slow method is to command/control+A to select all the points and then choose the Transform Points tool and click in a blank area of the workspace to keyframe all the points (while also hoping that you don't jiggle the points when you click), and then repeat the process for point curvature. Note: command/control+F does NOT make key frames for bones when you are on a vector layer, which is great.
:idea: When you want to freeze the pose of a selected bone, you don't need to go to the Bone Menu and choose Freeze Selected Bones to make a keyframe. Instead, locate the channel(s) for the selected bone on the timeline. Recall that the icon(s) for the selected "bone" is red. Double-click on the red line to create a keyframe at that spot. That's it! Note: the playhead does not have to be on that frame.
I hope somebody found these tips useful. Feel free to share other time-saving tips.
Re: Time-saving Moho tips
Good list!
Hoptoad wrote: Sat Apr 01, 2023 8:17 am :idea: If you hold down the ALT key while using the Manipulate Bones tool, the tool acts like the Transform Bone tool and only rotates 1 bone.
What this actually does is it switches Manipulate Bones from IK mode to FK mode. So you do your broad posing with IK and press Alt to tweak and refine the pose. Between the two modes, you can get the perfect pose very quickly.
When you want to freeze the pose of a selected bone, you don't need to go to the Bone Menu...
I don't know if you've tried MQC (Moho Quick Click) but it does some of what you described (Freeze Points, Freeze Pose, etc.,) from a button panel. I made it back when I used Moho on a Wacom tablet computer, which didn't have a keyboard, so I could just tap buttons on the screen instead of going to the menus. I found that MQC also made Moho easier with a mouse on extra large display because I didn't have to keep mousing across the screen to the menus for everything (coz I'm too lazy to memorize all the shortcuts. :P ) If you haven't tried MQC yet, check it out here:
MQC For Moho Pro
I hope Moho gets something like this natively in the future. A moveable and easily customizable buttons panel is a must for tablet users. MQC is specifically set up for the way I use Moho but I'm sure other users may want different shortcuts in their button panel.
You might already know this one but it's pretty good...
You can press and hold any keyboard tool shortcut to temporally switch to that tool. When you release the key, the tool will switch back to what you were using last.
For example, if you're drawing with Add Points and you want to adjust the curvature of some points, press and hold C to adjust the points then release to continue drawing. This works for almost any tool that has a single button shortcut.
Earlier I said I'm too lazy to learn shortcuts but I lied. This is the reason I memorized the ones for all the Draw tools. (Hmm...but maybe I memorized them because I'm lazy? 😹)
Additional tip: The only time I find the above trick does not work so well for me is when posing a character and I want to temporarily switch from Manipulate Bones to Transform Bones for repositioning or scaling some bones. When I press and hold T, Moho gets very slow and chunky. In this situation, I find it's better to instead quick-press T to fully switch to Transform Bones to edit position and scale, and the quick-press Z to switch back to Manipulate Bones, and Moho stays speedy the whole time.
Hoptoad
Post by Hoptoad »
Greenlaw wrote: Sat Apr 01, 2023 9:09 am I don't know if you've tried MQC (Moho Quick Click) but it does some of what you described (Freeze Points, Freeze Pose, etc.,) from a button panel.
Alas, MQC only works on a Windows computer, and I have a Mac. I hope some of its features become native to Moho. For frequently used operations, buttons are way better than using the menu.
Greenlaw wrote: Sat Apr 01, 2023 9:19 am You might already know this one but it's pretty good...
I just tried your tip and it's amazing. This will be a huge time-saver on my vector art backgrounds. I like roughing-out shapes and adding and moving points as I go, so this tip suits my approach. Thanks!
Hoptoad wrote: Sat Apr 01, 2023 9:59 am Alas, MQC only works on a Windows computer, and I have a Mac.
Agh! That's too bad. I used AutoHotkey to create it but I imagine there must be an equivalent macro editor for Mac. Most of the buttons are just referencing normal shortcuts, and only one or two of the buttons have additional code to do multiple things. Should be easy to create something similar for Mac. (If anyone does this, please let me know about it because I occasionally get asked about a Mac version of MQC but I haven't owned a Mac for a while now.)
Before I made MQC, I used Wacom's OSD (On-Screen Display) button panel, which is similar but easier to assign buttons to. This worked great for a while but it's limited to 8 buttons, and by the time I needed to create a third OSD panel for Moho, I decided to make my own button panel using AHK. But if you have a Wacom device and only need 8-16 buttons, OSD works well.
Another option is to use a physical remote. So far I've tried XP-Pen AC19 Shortcut, Huion Mini Keydial KD100 Express Keys, Wacom Express Keys, and Xencelabs Quick Keys. They all work fine but the Xencelabs one is my favorite because it has an LCD panel that shows the labels for all the buttons as it changes modes from program to program, and each program can have multiple pages of buttons.
I haven't replaced MQC with a device but if I didn't have MQC, I'd probably be using one of these devices for Moho. (Actually, I do use the Xencelabs remote with Moho on my tablet computer for modifier keys when the keyboard is hidden. Very useful device!)
