Looping 2 frame Photoshop Image Sequence for jitter effect
Hi I am drawing in Photoshop and want to import 2 frames, 2nd drawn frame again, to create a natural jitter effect. I want to then cycle these 2 frames in Moho. Please help.
- alanthebox
Re: Looping 2 frame Photoshop Image Sequence for jitter effect
i suppose the easiest way to cycle a 2 frame image sequence in moho is to go to file / import / image sequence. then, in the layers panel, open the layer settings for this image sequence. next, go to the image tab, and select 'loop movie indefinitely. from that image tab, you can also play around with the movie fps to get a jitter speed that you like.
Thank you so much
