Bezier Keyframes in a Mac
Gaucho
Post by Gaucho »
Hello everybody!
I am using Moho Pro 13.5 in a Mac, and after trying any combination possible of "option/alt/shift/control" I am still not able to see the keyframes in the timeline when switching to Motion Graph. I only see the color lines alone (not keyframes) when I separate dimensions.
Any help would be appreciated!
Thank you!!!
Re: Bezier Keyframes in a Mac
While in the Graph Editor, you need to double-click on the channel you wish to edit. For example, if you want to edit the position of an item, double-click on the Translation channel icon. This will load the keyframes for that channel in the Graph Editor.
Gaucho
Post by Gaucho »
Greenlaw wrote: ↑Mon Feb 27, 2023 2:24 pm While in the Graph Editor, you need to double-click on the channel you wish to edit. For example, if you want to edit the position of an item, double-click on the Translation channel icon. This will load the keyframes for that channel in the Graph Editor.
That works like a charm!
Thank you very much Greenlaw!!!
