Actions panel doubt!!!
striker2311
Post by striker2311 »
Hello guys,
I was inserting a copy of a smart bone dial of several layers into another smart bone dial using insert copy (which comes after right-clicking on an action) but after I did that I noticed that it only transform point's keyframes are copied not curvature's keyframe.
So, I want to know am I doing something wrong or it has been like that, and if it is like that then is there a way to copy exactly a smart bone dial into another ?
and I heard this function can also be performed through mult Rush's transform script but I couldn't figure out how I can do that, so is there anyone who might know how to do that.
I only want to copy one smart bone dial into another (or simply say) want to duplicate a smart bone dial.
Re: Actions panel doubt!!!
I just tried to do it here with Moho13.5.5 and it worked fine. I transfered every keyframe (including curvature keyframes) from the smartaction 1 to the smartaction 2, selecting the bone layer, then entering the smartaction 2, going to the frame 1, clicking on the smartaction 1, and clicking on insert copy. Edit: I forgot to finally select the smartbone 1 and delete its keyframes from the smartaction 2.
striker2311
Daxel wrote: Thu Feb 16, 2023 2:50 pm I just tried to do it here with Moho13.5.5 and it worked fine. I transfered every keyframe (including curvature keyframes) from the smartaction 1 to the smartaction 2, selecting the bone layer, then entering the smartaction 2, going to the frame 1, clicking on the smartaction 1, and clicking on insert copy. Edit: I forgot to finally select the smartbone 1 and delete its keyframes from the smartaction 2.
Yes, I tried again copying action and it worked this time.
For future if anybody faces this issue, try to remove the keyframes of original smart bone from copied smart bone. (remove smart bones rotation of smartbone 1 from smart bone 2 in above context).
