Select layer and update tool?
bbrraayyaann
Post by bbrraayyaann »
Hello friends, how are you.
I am using the function: ScriptInterface:SetSelLayer(layer) to select a layer, but for example if I am in a bone layer and I select a vector layer, it does not update its corresponding tool, when I select the vector it should change to drawing tool, but it stays in the bone tool for example. Would anyone please know how to do it?
bbrraayyaann
Re: Select layer and update tool?
I was going through scripts and came across this.
I have also tried everything; but I think this is the only solution?
If there is another way let me know.
This script: https://mohoscripts.com/script/sz_layer ... on_buttons
					-- These are the methods I tried, and none of them updates the tool panel:
					-- moho:UpdateUI()
					-- moho.view:DrawMe()
					-- moho.view:RefreshView()
					-- layer:UpdateCurFrame(true)
					-- MOHO.Redraw()
					-- moho:UpdateSelectedChannels()
					-- moho:UpdateBonePointSelection()
				-- That's why we have to do some dark magic here instead:
				local sacrificialLayer = moho:CreateNewLayer(MOHO.LT_UNKNOWN)
				moho:DeleteLayer(sacrificialLayer)
You might also try jumping to/from frame zero and back. That's another thing that reliably reevaluates the tools window.
bbrraayyaann
But it works when you use PickGlobalLayer :
function Pickckckc:OnMouseUp(moho, mouseEvent)
	local layer = mouseEvent.view:PickGlobalLayer(mouseEvent.pt)
	if layer == nil then return end
	if (layer == nil or layer == moho.layer) then
		return
	end
	moho.document:ClearSecondarySelection()
	moho:SetSelLayer(layer)
	moho:ShowLayerInLayersPalette(layer)
	moho:UpdateUI()
end
bbrraayyaann
synthsin75 wrote: Wed Feb 08, 2023 3:57 pm You might also try jumping to/from frame zero and back. That's another thing that reliably reevaluates the tools window.
Ah, that works well too, thanks
