PNG are visible only blurred on frame 0 on stage
Sandra HH
Post by Sandra HH »
Hey,
I'm currently animating in Moho 15.3 using various PNGs with transparencies. How can I set the view so that I can see the PNGs clearly on my stage even without play and is there also a way to see the PNG elements in the 3D view from above not only as gray areas?
Thanks a lot for your support.
Best regards
Sandra
Re: PNG are visible only blurred on frame 0 on stage
I wonder if this is caused by GPU Acceleration. Try disabling the option from Display Options. If it's already off, try enabling it.
FYI, I normally keep this off because masking effects tend to work better when it's off.
If that's not it, I'd really need to see a screen cap or project file, because I don't normally have a problem with blurry images in Moho.
Sandra HH
Post by Sandra HH »
Thank you very much @greenlaw,
it was a totally embarrassing mistake of a beginner, but unfortunately it happened that way. I was always working with vectors in Moho before and had the raster turned on for that reason. Then when working with PNGs everything looks quite strange, like through a veil. Yes it is embarrassing ... :oops:
Thanks for your effort
Sandra
It's nothing to be embarrassed about. We all learn here by asking questions. :D
