Timeline Sped Up
shift
Timeline Sped Up
Post by shift »
I am playing back my timeline and it is playing at double speed. I have restarted the app and checked project settings but it still plays back faster than I want it to so I cannot get a true sense of the timing until I render. This is Moho 13.5.5
Re: Timeline Sped Up
Are you using physics?
Is it still fast after you let it play through once and loop back?
You can always try disabling frame skipping.
shift
Post by shift »
Interesting that you mentioned physics. So I have an object following a path. I notice when I delete that object it plays at normal speed but once I reintroduce the object, the timeline speeds up again.
If you could post a file with just enough to show the problem, it might help the devs sort it out...if it's repeatable.
