Hi guys,
I've what might be a very stupid question. Is there a way to make the animation stop at the end of the blue area of the timeline? Mine keeps looping the animation endlessly. That isn't a problem while working on a fairly short scene (a few seconds). But I'm working at the end of a fairly long scene and get annoyed that I have to keep pressing 'Jump to end' button.
I know, I can use the arrow keys to 'scrub' the timeline but that brings a 'slow motion' effect and I would like to see the animation at a more natural speed.
I looked at the preference menu but couldn't find any settings there. I would be surprised if a sophisticated program like Moho doesn't have already an option for such a simple problem.
Thanks in advance!
Can I make the animation in the timeline stop at the end?
- Hugging_Bear
The Guardian of Tales - YouTube Channel
https://www.youtube.com/@guardianoftales
Re: Can I make the animation in the timeline stop at the end?
I assume that you're talking about the playback in project view.
You can always shorten the area of playback by alt-right-cllick and alt-left-click in the frame number line of the timeline.
Making Moho play back only once is not possible.
- hayasidist
This is a layerscript. It will stop playback after one run. It affects only the document in which it is active. You still need to press "stop" to reset it.
Add it to ANY layer that is visible (layerscripts only run if the layer is evaluated) OR add it to a "dummy" layer and use layer visibility to enable / disable its functionality.
any issues let me know!
function LayerScript(moho)
local myKey = "hs_start_" .. moho.document:Name()
local wasPlaying = "hs_play_" .. moho.document:Name()
local stop = _G[wasPlaying] and not moho:IsPlaying()
local stopped = not moho:IsPlaying() and not _G[wasPlaying]
if stop then
MOHO.MohoGlobals.PlayStart = _G[myKey]
end
if stopped then
_G[myKey] = MOHO.MohoGlobals.PlayStart
end
if moho:IsPlaying() then
MOHO.MohoGlobals.PlayStart = moho.frame
end
_G[wasPlaying] = moho:IsPlaying()
end
- Hugging_Bear
Thanks Slowtiger! You saved my day! (and many to follow). The alt-left-click tip was just what I needed. I don't mind the looping at the last few seconds of the scene, as long it isn't jumping back at its very beginning.
- Hugging_Bear
Thanks for your tip but I'll go with slowtiger's solution. Yours seems a bit complicated and a lot of work.hayasidist wrote: ↑Thu Dec 29, 2022 5:58 am This is a layerscript. It will stop playback after one run. It affects only the document in which it is active. You still need to press "stop" to reset it.
any issues let me know!Code: Select all
function LayerScript(moho) local myKey = "hs_start_" .. moho.document:Name() local wasPlaying = "hs_play_" .. moho.document:Name() local stop = _G[wasPlaying] and not moho:IsPlaying() local stopped = not moho:IsPlaying() and not _G[wasPlaying] if stop then MOHO.MohoGlobals.PlayStart = _G[myKey] end if stopped then _G[myKey] = MOHO.MohoGlobals.PlayStart end if moho:IsPlaying() then MOHO.MohoGlobals.PlayStart = moho.frame end _G[wasPlaying] = moho:IsPlaying() end
