HS_Shape V10
HS_Shape V10
It's here: https://mohoscripts.com/script/hs_shape (I hope I've managed to navigate that site's upload process correctly!!)
and also here: https://www.mediafire.com/file/d2ecsb72 ... 0.zip/file
The .zip has an install folder and a readme.
What’s new in this version (since version 9.67)?
Totally re-architected. This version is the foundation for the next revision which is intended to allow user-written sub-tools to be accommodated.
Added the “additional functions” for help and re-set subtools (see below).
Enabled the “ratio / scale” (floating point input) so that it can be changed (and thus change the drawn shape) immediately after the shape is drawn.
A keystroke handler is introduced. Ctrl-key directs the keystroke to the factory SelectPoints keystroke handler (this only services “delete selected points” at present); key (or alt-key or shift-key) is handled within this tool – again only “delete selected points” is currently supported. This difference is that the factory tool will delete all selected points; this tool will only delete points from the last shape created by this tool if it is “editable”.
The main set of drawing tools is essentially unchanged from V967 (Moho 13.5.3) from 07 April 2022.
There is a new (version 1.04) sub-tool to draw card suit shapes. This is provided as a separate file in the Utility folder.
The “additional functions” button (to the left of the sub-tool buttons) changes the behaviour of the sub-tool selection buttons.
Clicking (or alt-clicking) the button cycles forwards (or backwards) through the options:
>>> O – normal operation of the sub-tool
>>> R – reset the sub-tool’s options (and leave the sub-tool active)
>>> ? – print the sub-tool “help/about” message (and leave the sub-tool active)
Editing a shape
Having drawn a shape using a sub-tool it is possible to change the detail of the shape by, optionally, changing a numeric input field (other than those that directly or indirectly define the number of points in the shape) and then holding down the control key and simultaneously clicking and dragging the mouse. Once the edit operation is in progress the control key may be released if its shape modifying action is not required. Note that the shift and alt keys remain set as they were when the shape was created.
Also, where the sub-tool uses the floating point input to control scale / ratio / roundness (etc) this value can be modified immediately after the shape has been drawn to change the drawn shape.
If a shape is created on frame 0 (e.g. with the “create on frame 0” checkbox checked) then modified on a different frame (with the “create on frame 0” checkbox unchecked) the shape will be animated.
This video expressly shows the round-cornered rectangle, and how it can be edited and animated. The same is available for any of the subtools that use the "floating point" input field (all the card suits, swiss cross, parabola, multi-line, sine, star, annulus, (vector) bone shape)
Problems / issues / requests -- please say!
Re: HS_Shape V10
Great new features, Paul!
Personally, I always download from mohoscripts as simple ZIP.
In that case, it helps if any utility files are named to indicate that's where they go.
So I just grabbed your mediafire one instead.
Re: HS_Shape V10
Version 10.01 is now available. It is a minor bug fix ... a Lua console message is generated when creating a path that does not result in a Moho shape being created (the path is correctly created -- the error message is an annoyance only).
Links are as in the original post.
Any problems or issues, please let me know.
Re: HS_Shape V10
Cool! Thanks Paul...will download and install today and let you know how it goes.
martin_mrt
Re: HS_Shape V10
Post by martin_mrt »
Hello there,
Just found this awesome script after not being able to quickly draw a six sided polygon.
Everything works but I get this error message on startup: "Moho Pro\Scripts\Tool\hs_shape.lua:466: attempt to call a nil value (method 'identify')"
Using Moho 14.4.
Thanks for making this tool! Its an awesome addition to the Shape Drawing Tool
Re: HS_Shape V10
martin_mrt wrote: ↑Wed Mar 18, 2026 2:27 am Hello there,
Using Moho 14.4.
can you check the tool version number please (just hover over the tool icon) - latest is 10.20; also the error message -- there isn't a call to an Identify method on 466.
Maybe 446? But that call creates the tool bar - and if that fails, then there won't be a tool bar???
martin_mrt
Re: HS_Shape V10
10.20
yes 446. you are right.
Re: HS_Shape V10
@martin_mrt, Just chiming in to say it's working fine here, version 10.20 in Moho 14.4 for Windows; no errors.
So, it should be working. There are a lot of files for the script, so make sure they're all installed correctly.
If that's not it, maybe a conflict with another script? Try setting up a clean Custom Content Folder and installing only HS Shape there to test.
Re: HS_Shape V10
martin_mrt wrote: ↑Wed Mar 18, 2026 8:51 am 10.20
are all the subtool icons displayed? (https://mohoscripts.com/script/hs_shape - scroll down to the line Subfolder: hs_shape_icons -- you should have all of those except the "!T" which is a test icon) If there are some missing, that starts to suggest that the source file is damaged - or (as Greenlaw hints at) maybe you have an older version installed as well????? (this is the first report of this issue - the "Identify" method is central to the way the tool knows which subtools it has)
martin_mrt
Re: HS_Shape V10
All the Icons are there. I dont have an older version installed. I found it just then (very happy to have found it!)
I just extracted the archive again and overwrote the files to make sure it was no copy error.
I encountered it initially on my desktop system and now tried it also on my laptop where i share the same custom content folder. The message appears there too. So I guess it must be something on the level of the file.
Will try the clean install sugessted by Greenlaw next.
... theres one particularity: in my tools window under other some of the icons are displayed again but as crossed out questionmark as if it wouldnt have found the png. but its right next to the same button with the psd displayed. can it maybe have to do something with that??
Re: HS_Shape V10
martin_mrt wrote: ↑Thu Mar 19, 2026 11:28 am All the Icons are there. I dont have an older version installed. I found it just then (very happy to have found it!)
feels as though there's something wrong in your custom content folder -- maybe duplicated <tool>.lua ??? one with "the right name" e.g. HS_Shape.lua and one with the wrong one e.g. HS_Shape - Copy.lua?????????? but I'm guessing blindly here
Re: HS_Shape V10
martin_mrt wrote: ↑Thu Mar 19, 2026 11:28 am Will try the clean install sugessted by Greenlaw next.
Just to be clear, all you need to do is set Moho to a different folder name, and it will generate a clean Custom Content Folder for you. I sometimes make multiple Custom Content Folders this way to test different situations. You can repoint Moho to any Custom Content Folder at any time. (Use Shift+Ctrl+Alt+L to reload, or just relaunch Moho.)
Even for everyday use, I keep one default (i.e., clean) Custom Content Folder and one modified Custom Content Folder for each installed version of Moho (see below for example). This setup has been very useful and convenient for troubleshooting script issues.
So, just have Moho create a new one, drop in the Shapes folders, relaunch, and you'll know immediately whether the issue is with the script or the other Custom Content Folder.
Hope this helps. 😺
martin_mrt
Re: HS_Shape V10
Ok, I made a completeley new ccfolder, with latest versions of all the scripts. Now there is no errormessages.
After writing the messages here i got them also from another script. so definiteley something was wrong with my setup. Its the first ccfolder i used when starting with moho about 2-3 years ago. my guess is i copied something in the wong folder or an old script made problems.
its really neat now! no "ghost" icons. my vitruvian bones are with bones ond not other. Springclean! :D
Thanks for the support & help and sorry for sounding a wrong alarm in this thread!
Re: HS_Shape V10
Yeah, I ran into a similar problem not long ago, but with using Rai's Shapes Window. Whenever I ran a newly installed version of the script, an older version of the tool would run instead. This didn't make sense because I thought I had removed all the older files. With Rai's help, we found a copy of an older version hidden in a different menu folder. I created this folder as an experiment, forgot about it, and later it was effectively overriding the newer version. Because of the forgotten test folder and file, the cause of the error was tricky to find and fix.
After removing the 'hidden' file, the new tool runs great now. Whew! 😸
Re: HS_Shape V10
martin_mrt wrote: ↑Tue Mar 31, 2026 4:58 am Ok, I made a completeley new ccfolder, with latest versions of all the scripts. Now there is no errormessages.
no worries. glad you got it sorted.
Adding to what Greenlaw has said about "hidden old versions" ...
Now it looks as though it was probably old scripts in your custom content folder, that's triggered a long buried memory (if memory serves me well) about a situation where a script hadn't set its identifier properly and that meant that its code, and the code in previously processed script that had identified itself properly, got somehow mixed / messed up?? IIRC symptoms included the tools icon issues and unexplained error messages from an otherwise "innocent" tool -- but, ofc, I can't find the thread ...
