Hi there,
Just having some issues with the Follow path tool. The object I want to move seems to be offset very far from the path I am selecting…also it does not seem to be making key frames when I click on the path at start and at finish frame.
Cheers.
Follow path issue
- Víctor Paredes
Re: Follow path issue
Check the origin of your layer. You can use the Origin tool on frame zero to modify it.
That's the information Follow path uses to center a layer.
cool thanks Victor, will do
