Scripting:Problem when trying to Use Dialog()
bbrraayyaann
Post by bbrraayyaann »
Hi, I am trying to create a PopUp in Moho.
But when I use the Bone selection tool,
and then using the pop up of my script in Moho it closes.
Here is the Lua file : https://www.mediafire.com/file/tl4vdmy5 ... g.lua/file
Could someone please test if the same thing happens to you?
bbrraayyaann
Re: Scripting:Problem when trying to Use Dialog()
bbrraayyaann wrote: ↑Thu Nov 17, 2022 3:47 am
Well, I found the solution:
If I create a new dialog, it must go in order and it must have
UpdateWidgets , HandleMessage.
In the order Dolayout , UpdateWidgets(Dialog) ,HandleMessage(Dialog)
And finally the main HandleMessage.
I did it in that order and it finally worked.
