Patch layer not moving with joint
Tryll
Post by Tryll »
Using Moho 12.5x
I've added a patch layer to a joint, and it renders properly but doesn't move with the joint during bone manipulation.
Originally it was in a sub-group, but even if I put all the layers directly beneath the bone layer the issue persists.
What am I missing?
SuperSGL
Re: Patch layer not moving with joint
Post by SuperSGL »
Everything should be inside your bone layer. The patch layer should be just above the layer your blending. You also have to choose the target Layer (your joint layer). If it still doesn't look right do a test animation to see if it stays with your joint.
Norman McLaren
My Animations
By default, I think the Patch layer tries to use the binding method used by its target layer, but I prefer to manually bind the Patch layer to the bone I want it to use. If you're not already doing that, try using the Bind Layer tool to bind the Patch layer to the bone you want it to follow.
The reason I do this is mainly because the bone I usually want is not the target layer's bone but the parent bone. Also, I think explicitly binding the patch layer is more reliable.
Tryll
Post by Tryll »
Greenlaw wrote: Mon Oct 17, 2022 1:02 pm By default, I think the Patch layer tries to use the binding method used by its target layer, but I prefer to manually bind the Patch layer to the bone I want it to use. If you're not already doing that, try using the Bind Layer tool to bind the Patch layer to the bone you want it to follow.
Thanks. This was pretty much what I needed to do as well, and I had tried it, but I probably did things out of sequence.
I went back and reworked it and was able to manually bind the patch to the parent bone properly and it seems to be working (even when encapsulated into a masking group as well.)
Thanks for the pointers.
