Hi everyone
I' ve a char with a switch layer for my different phoneme of the mouth.
I've start my animation but i notice that i've forgot a mouth position. so i return to frame 0, add a layer on my switch groupe, but back to the animation, i' still see the keyframe on the switch layer, but nothing's moving and even mouth is deformed.
Is that normal (impossible to change before started animated) or is there a way to achieve that
thank you
have a nice day
add a layer on a layer switch after beggining the animation
Re: add a layer on a layer switch after beggining the animation
You can freely add new child layers to a existing Switch layer.
Switch layers work by selecting the child-layer by name - so don't care what was added when.
The only reason nothing moves/changes (in your scenario) - would be if/when you have one of the child switch layers selected - which makes it 'visible'.
- Víctor Paredes
Yes, if you select a layer inside of a switch layer, Moho will prioritize its visibility during the preview, so you can edit and animate it without losing the focus.
If you want to change this and always see the current active layer, even when another layer is selected, just go to View -> Active Switch Layer Only
oh thak you, you're right it was my new layer that was display overall. But here is even a trouble.
I duplicate an existing mouth (vector layer) , to deform it and create an new phoneme. in frame 0 everything ok, but when i go on the timeline, there is some Y or X mirror on my new mouth. Do you ever experimente this?
https://drive.google.com/file/d/1l_eTA0 ... sp=sharing
Without seeing the actual file, I'm guessing the new drawing is being affected by bones outside of the head/mouth. If this is the case, there are ways to prevent that:
1. Layer Bind the Mouth Switch to a head or mouth bone. This will prevent any other bone from deforming the mouth drawings by Bone Strength. Of course you can still use Smart Bones to animate the drawings. This is the method I normally apply because it's simple, clean and predictable.
...or...
2. Use Selective Flexi-bind to bind each drawing to a mouth bone. This is a little more work but you can speed binding up by selecting all affected layer and apply the command in one go. The advantage with this method is that you can still use other bones to affect the drawings when you need to.
If a art or layer is actually being flipped, check that this isn't occurring in a Smart Bone action or somewhere in the Mainline. Check the points, layer, and parent bone for any keys that might flip the image.
