Scripting : How to get the interpolation values for a cycle?
bbrraayyaann
Post by bbrraayyaann »
Hello, I have a question about the class:
AnimChannel:GetKeyInterp(when, interp).
I want to get the val1 and val2
of a loop and store it
the absolute value and relative value
Is it possible to get those values?
I was trying something like this :
local layer = moho.layer
local interp = MOHO.InterpSetting:new_local()
layer.fTranslation:GetKeyInterpMode(moho.layerFrame,interp)
interp.interpMode = MOHO.INTERP_CYCLE
print("Relative value: " ..interp.val1)
print("Absolute value: " ..interp.val2)
But it does not work
Does not print the correct values
If someone could tell me how to do that ? Thanks
SimplSam
Re: Scripting : How to get the interpolation values for a cycle?
Post by SimplSam »
GetKeyInterpMode returns the Interpolation Mode only, and allows you to determine if it is Smooth, Linear, Cycle etc.
You will then need to use GetKeyInterp to get the interp object.
local keyInterp = layer.fTranslation:GetKeyInterpMode(moho.frame)
if (keyInterp == MOHO.INTERP_CYCLE) then
  layer.fTranslation:GetKeyInterp(moho.frame, interp)
end
bbrraayyaann
SimplSam wrote: ↑Mon Aug 01, 2022 2:54 am GetKeyInterpMode returns the Interpolation Mode only, and allows you to determine if it is Smooth, Linear, Cycle etc.
end
Hi, Thank you very much Sam
I found your answer helpful, I already got the correct values.
