Vector layer Noise Settings
ggoblin
Post by ggoblin »
Hi, I'm trying to set a vector layers noise settings from script.
These are the settings you would use layer settings -> vector panel in the UI to set:
to produce this effect:
I found most of the settings in the Mesh Layer properties, with a few caveats :
1. fNoiseAmp and fNoiseInterval appear to be in moho units in the script whilst they are in pixels in UI, so unless you want to see wildly jumping lines you need to divide the values by 1080 (on a 1080p canvas) before using them in the script. (This should be documented in the API guide - it actually has no documentation on these fields other than their name and type)
2. In the UI there is a 'Line Count' box, in the script there is fExtraLines , so obviously fExtraLines has to be set to one less than Line Count.
But the problem I'm having is setting the Noise Interval - by default its 1 frame, too fast for me, I need it at 3 frames. But I can't find the field in the Moho API documentation. I did come across a script in Mohoscripting.com which refers to fNoiseInterval in a comment. I tried setting it but it was ignored.
I cannot believe the API would leave out one of the key parameters to setting layer noise whilst including all the others, but I can't find it. Any help would be much appreciated. Thank you.
Re: Vector layer Noise Settings
oh the joys of being a pioneer! all those "nuggets" to discover. :roll:
Formal request for access to "interval" has been lodged. I also can't see a workaround short of hacking the .mohoproj ...
as for the other observations - I'll aim to get an update to mohoscritping done "soon"!
ggoblin wrote: Thu Jul 21, 2022 12:21 am fNoiseAmp and fNoiseInterval ... are in pixels in UI .... (This should be documented in the API guide - it actually has no documentation on these fields other than their name and type)
Updates to mohoscripting done.
and
Found this http://lostmarble.com/forum/viewtopic.php?p=137698 from nearly a decade ago! Might be useful!
Lukas
Post by Lukas »
hayasidist wrote: Sun Jul 24, 2022 10:43 am
and
Ah, I forgot about that thread.
I'll share the scripts we ended up creating and using for a Dutch TV-Show called Buitenspelen / Outside, here's a link to an epsisode about: penguins and gnomes
No idea if these still work in the latest Moho, but maybe they're useful to you as a starting point. I haven't checked them out or tested them. If I recall correctly, the first one turns on a jiggle vector effect for all(?) layers, the second one too but with more extreme values, the third one turned it off (we needed it to be turned off while animating).
We called it the Schaaik-effect because that was the directors name and he established the style before we got on board. It was a fun project.
-- Provide Moho with the name of this script object
ScriptName = "LK_Schaaikeffect"
LK_Schaaikeffect = {}
function LK_Schaaikeffect:Name()
	return "Het Schaaik effect standaard"
end
function LK_Schaaikeffect:Version()
	return "0.1"
end
function LK_Schaaikeffect:Description()
	return ("Schaaik-effect standaard")
end
function LK_Schaaikeffect:Creator()
	return "Lukas"
end
function LK_Schaaikeffect:UILabel()
	return("Schaaik-effect standaard")
end
-- The guts of this script
function LK_Schaaikeffect:Run(moho)
	moho.document:PrepMultiUndo()
	moho.document:SetDirty()
	for j = 0, moho.document:CountLayers()-1 do
		local layer = moho.document:Layer(j)
		self:ConvertLayer(moho, layer)
	end
LM.GUI.Alert(LM.GUI.ALERT_INFO, "Alle lagen zijn klaar om buiten te spelen!")
end
function LK_Schaaikeffect:ConvertLayer(moho, layer)
	if (layer:LayerType() == MOHO.LT_VECTOR) then
		local vectorLayer = moho:LayerAsVector(layer)
		vectorLayer.fNoisyLines = true
		vectorLayer.fNoisyShapes = true
		vectorLayer.fAnimatedNoise = true
		vectorLayer.fExtraSketchy = false
		vectorLayer.fExtraLines = 0
		vectorLayer.fNoiseAmp = 6.0 / moho.document:Height()
		vectorLayer.fNoiseScale = 48.0 / moho.document:Height()
		local mesh = vectorLayer:Mesh()
		for k = 0, mesh:CountShapes() -1 do
			local shape = mesh:Shape(k)
			shape:MakePlain()
			local brush = LM.String:new_local("Brush001.png")
			shape.fMyStyle:SetSoftEdge(18.0 / moho.document:Height())
			shape.fMyStyle.fBrushName = brush
		end
	elseif layer:IsGroupType() then
		local groupLayer = moho:LayerAsGroup(layer)
		for i = 0, groupLayer:CountLayers()-1 do
			local subLayer = groupLayer:Layer(i)
			self:ConvertLayer(moho, subLayer)
		end
	end
end
ScriptName = "LK_Schaaikeffect_More"
LK_Schaaikeffect_More = {}
LK_Schaaikeffect_More.BASE_STR = 2480
function LK_Schaaikeffect_More:Name()
	return "Het Schaaik effect"
end
function LK_Schaaikeffect_More:Version()
	return "0.1"
end
function LK_Schaaikeffect_More:Description()
	return ("Schaaik-effect plus")
end
function LK_Schaaikeffect_More:Creator()
	return "Lukas"
end
function LK_Schaaikeffect_More:UILabel()
	return("Schaaik-effect plus")
end
function LK_Schaaikeffect_More:Run(moho)
	end
end
function LK_Schaaikeffect_More:ConvertLayer(moho, layer)
		vectorLayer.fNoiseAmp = 12.0 / moho.document:Height()
		vectorLayer.fNoiseScale = 70.0 / moho.document:Height()
			shape:MakePlain()
		end
		end
	end
end
ScriptName = "LK_Schaaikeffect_Off"
LK_Schaaikeffect_Off = {}
LK_Schaaikeffect_Off.BASE_STR = 2480
function LK_Schaaikeffect_Off:Name()
end
function LK_Schaaikeffect_Off:Version()
	return "0.1"
end
function LK_Schaaikeffect_Off:Description()
	return ("Zet Schaaik-effect uit")
end
function LK_Schaaikeffect_Off:Creator()
	return "Lukas"
end
function LK_Schaaikeffect_Off:UILabel()
	return ("Zet het Schaaikeffect uit")
end
function LK_Schaaikeffect_Off:Run(moho)
	end
LM.GUI.Alert(LM.GUI.ALERT_INFO, "Alle lagen zijn weer binnen televisie aan het kijken als een stel zombies!")
end
function LK_Schaaikeffect_Off:ConvertLayer(moho, layer)
		vectorLayer.fNoisyLines = false
		vectorLayer.fNoisyShapes = false
		vectorLayer.fAnimatedNoise = false
		vectorLayer.fNoiseAmp = 0 / moho.document:Height()
		vectorLayer.fNoiseScale = 0 / moho.document:Height()
			shape:MakePlain()
		end
		end
	end
end
ggoblin
Post by ggoblin »
and
Thank you Hayasidist for updating mohoscripting.
The forum link you shared seems to be kinda identical to what I discovered.. only it over 12 years old! If it was pointed out 12 years ago and still hasn't been fixed then I don't see much chance of it ever being fixed. :(
ggoblin
Post by ggoblin »
Lukas wrote: Mon Jul 25, 2022 1:45 am
Thank you Lukas for sharing.
The Dutch TV_Show is kinda unique in that its a Moho animated feature which is NOT character focused and yet won a Dutch Academy Award. It shows the potential Moho had back then when it was truly an all in one 2d animation solution, before it just started focusing on character animation. A pity for such a lost opportunity.
I see the scripts could not fix the missing fNoiseInterval API and ended up compromised, 12 years later its still not fixed. Such a shame that Moho owners have apparently failed to see the potential in using Moho for 2d non-character animation, and hence have let it fall behind so badly.
