Callipeg for ipad
Callipeg for ipad
I haven't even got an ipad ( hate apple) but thought this was compelling, it exports json btw
- hayasidist
Re: Callipeg for ipad
before getting too excited about "JSON export" ... viewtopic.php?p=204438#p204438
a VERY cursory look at Callipeg suggests it uses the After Effects JSON syntax (which might be a format TVPaint and Harmony (and Lottie??) support?????). [I haven't done any in-depth research on how AE / TVP / Harmony use JSON; but the link above gives a tiny snapshot of Lottie JSON vs Moho JSON -- they're so TOTALLY different to the point that I personally wouldn't even try to consider some form of 'converter'.]
Moho's use of JSON is proprietary. But that doesn't mean it can't adopt a different standard syntax in a future release to deliver increased compatibility / integration with AE!
with you there Chucky! Supplier of last recourse for me...
Ahhh, I did doubt that there could be any possibility to link the two.Thanks for the interesting info Paulhayasidist wrote: ↑Tue Jul 12, 2022 1:40 am before getting too excited about "JSON export" ... viewtopic.php?p=204438#p204438
I certainly won't be using callipeg, but it certainly is interesting and throws down the gauntlet for workstation apps.
TVPaint uses a certain JSON script which is tailor-made to match Adobes AfterFX import specifications (note: import only works in AFX default configuration), regarding naming and numbering of layers and frames.
Callipeg is a great piece of software for the iPad. I haven't used the export much (as really Callipeg does it all for animation), but the json export is to TVPaint, Harmony and After Effects. However, it appears that you need to run a downloaded script in those host applications to import the json file. In doing it for TVPaint, it appears to be just image files and layer and timing info. So, it should be somewhat routine for a script writer to write one that imports into any other program.
The other nice thing is the .oca export which can be used for Blender import. So, really Callipeg is extendable to a number of other apps and such.
- lucasfranca
I think it only exports the created sequence in svg or png layers in sequence. This approach can be called "Universal". Can this be done in Moho?hayasidist wrote: ↑Tue Jul 12, 2022 1:40 am a VERY cursory look at Callipeg suggests it uses the After Effects JSON syntax (which might be a format TVPaint and Harmony (and Lottie??) support?????). [I haven't done any in-depth research on how AE / TVP / Harmony use JSON; but the link above gives a tiny snapshot of Lottie JSON vs Moho JSON -- they're so TOTALLY different to the point that I personally wouldn't even try to consider some form of 'converter'.]
Look this: https://mohosvg.herokuapp.com
https://youtube.com/animai2D
I used Callipeg for a few weeks last year, and it's probably the only animation app I'd take seriously on iPad. Most iPad apps are just toys but this one has decent FBF tools and also a transform layer for non-destructively transforming child groups and layers. The drawing UI takes a lot from Procreate, which is pretty smart considering how Procreate has become the 'pro' standard for iPad painting. It's very capable, actively developed, and a lot of fun to use...so Callipeg meets my qualifications anyway!
I only stopped using it because I had too many other things going on at the time, and there's so much to remember that I found myself taking too much time re-learning it each time I came back. (Not as bad as when I come back to ZBrush, but almost.) I'm sure I'll come back to it someday. I was hoping my child would pick up on it. They use Flip-A-Clip and they complain that it does not have tools for non-destructive transforms, but right now I think they're too busy to learn another animation app.
As for supported export formats, (opening app now):
Callipeg
PNG
PSD
MP4
HEVC (with Alpha)
GIF
JSON
OCA
Funny...at the bottom of the Export tab a button for 'To Import To Blender', which I'm sure is just a weblink, but I think it shows consideration for users who want/need to use the app as one of many within a pipeline. (Just like Moho!)
If I was actively using Calipeg right now, I'd be using PNG (for comp and editing on a desktop,) followed by GIF and HEVC (for direct to web use.) I'm not sure sure what Calipeg's maximum color depth is...probably 24-bit color but I should look into that.
Callipeg
PNG
PSD
MP4
HEVC (with Alpha)
GIF
JSON
OCA
Really great review, Greenlaw!
I would post some of my Callipeg animations but they're just really dumb tests.
Well, lemme think about it...dumbness hasn't stopped me before.
