Removing Soft Edges
ggoblin
Removing Soft Edges
Post by ggoblin »
How do I remove a soft edge from a shapes style?
I tried setting it to 0:
myshape.fMyStyle:SetSoftEdge(0)
but that just sets it to 0 but still keeps it.
Surprisingly I couldn't find one script on MohoScripts.com that has uses the command SetSoftEdge, so have no example of how to undo its effect.
I tried removing all the styles using
myshape:RemoveStyles()
but that seems to ignore soft edges
Is there another command I should be using, or am I going about it the wrong way?
Thank you for your help.
Re: Removing Soft Edges
You need to use:
shape:MakePlain()
But like what you tried with RemoveStyles (which is for removing saved, "inherited" styles), this removes all shape effects.
ggoblin
Post by ggoblin »
Thank you Wes for the swift response, will give it a go! :D
I wondered how I missed it.. but checking the documentation.. its very sparse
Who needs documentation when we have Wes :D
Just added a description to mohoscripting.com.
ggoblin
Post by ggoblin »
Wow that was quick!
And it works brilliantly, thank you Wes! :D
BTW I didn't mean to critisise mohoscripting.com. It an invaluable, essential resource for all scripters. And considering that its created and maintained by volunteers as there is no official documentation of the Moho API, I can only admire and praise those that dedicate to this essential task for the community.
