How to add masking multiple shape with stroke invisible inside are of the mask ?
Trizul96
Post by Trizul96 »
Hi, I currently trying to combine 2 part of shape into masking area, but I got a problem. The stroke of the upper layer is still on the masking area which I want to get of rid this stroke from masking area. I spending a lot of time watching video and trying to browse online, but still not get the answer yet. Can you help me to solve this problem, here the picture https://drive.google.com/file/d/19HyMw4 ... sp=sharing Image
Re: How to add masking multiple shape with stroke invisible inside are of the mask ?
I think the feature you are looking for is: Layer settings - Masks - Exclude strokes
I'm not exactly sure what you're trying to do here. Are you trying to merge the two layer drawings like this?
Moho doesn't have interactive boolean effects but you can fake it a few different ways. The above example was done using two copies of the circle, one that's fill only and on top of the box that has both fill and stroke, and the other circle is behind the box with an double wide stroke applied. Here's the project if you want to look...
liveBooleanFake.moho
Another way to fake this is to use no stroke on the items, place them in a group, and enable Outline in the Group Properties. You won't see the effect immediately but it will appear in a render...
The 'gotcha' with this method is that the stroke exists outside of the shapes and not on top of the shape edges like a real stroke. But maybe that doesn't matter? Depends on the design and intent.
By the way, no masking is involved in either of the above hacks.
I'm sure users here can suggest other tricks but hopefully we'll get proper boolean effects in the future. 😸
I looked at your example and description again and I'm still not sure if the above is what you meant.
It would help if you could sketch out exactly what you want the result to look like. Otherwise, just guessing.
Oh, wait...in your example, is that the character's shoulder? Sorry, I didn't understand what I was looking at. In that case you probably want to use a Patch layer. See the manual for more info about how to use a Patch layer.
BTW, there's a way to create a Patch layer manually which offers some extra capabilities, like arbitrary Patch shapes and being able to use it with groups. A search in these forums will explain in detail.
Another way I've done this is to simply add a shape on top of the body and shoulder layers, which I can reshape to fit the situation. This shape is typically bound to a small bone that's parented to the upper arm. With this method, masking isn't needed.
I saw a clever trick by another user recently. Will post the link if I remember what that was.
Oh, one more thing: the arm should be split into two shapes at the elbow. This way the forearm can be properly layered on top of what's going on in the shoulder.
I made a post about 'seamlessly' splitting an arm at the elbow just the other day. It should be easy to find.
