Impossible to get evenly spaced particles following a path
Nicohk92
Post by Nicohk92 »
I have path in the shape of a horizontal wave.
I set a rectangle to follow that path (with layer bending option )from start to end with simple linear key points.
I put that rectangle in a particle layer in order to have multiple iterations of the move, emitted at a constant frequency (evenly spaced).
However that doesn't work. The particles are not evenly spaced.
Please see screenshot here:
https://www.dropbox.com/s/hpo6mtx21c3eg ... 1.jpg?dl=0
Can anyone help?
Thanks in advance
Re: Impossible to get evenly spaced particles following a path
If it's not too many duplicates, I just animate that rectangle once, then duplicate that layer as often as I need and shift each copy the same amount of frames in time.
