Soundtrack in a small file
LostMind
Post by LostMind »
I build a soundtrack for a Flash with "Audacity" but my first version was a 11mb soundtrack that finnally create a 23mb movie.
Do you know a way to create small file soundtrack or to compress a big that can be imported into Moho ?
aka False Dreams Land
-The Traveler and the Giant
-Security Programm: In creation
forgottenmementos.com/
If you use audacity... try experimenting with different "versions" of compression... instead of 16 bit try 8... try mono instead of stereo... etc...
I don't know what types of audio formats Audacity supports for export.
If you aren't using ANY compression for the file then it probably could get a lot smaller.
If you are using Flash than are you using MP3 format? Try a lower quality setting on export. I think Flash has the ability to "squish" the file size by adjusting the sound export settings.
-Vern
