How to transform image?
3deeguy
Post by 3deeguy »
This animation is an experiment. The image texture that fills the box doesn't have a perspective effect. I'd like to know how to bind it to a bone so I can distort it slightly.
Cheers, Larry
Re: How to transform image?
You can use a quad mesh to do that (We have been texturing many boxes for the movie here!). This tutorial could help you:
3deeguy
Post by 3deeguy »
Thank you for the education Victor. I had no idea quad mesh had that kind of power. It's time to upgrade.
Cheers, Larry
Quad mesh is definitely worth it:
SimplSam
Post by SimplSam »
synthsin75 wrote: Sun Apr 17, 2022 11:06 am Quad mesh is definitely worth it:
Very interesting use of 3D quad meshing. Were the original image planes flat - or did you chop up an already 3D image?
SimplSam wrote: Tue Apr 19, 2022 1:16 am
It was an image with the three sides you see at the start. Then skewed & masked to each referenced side of the quad mesh.
FloridaJo
Post by FloridaJo »
Very clear vid Vector.
I'm trying to do the same distortion of a book, but for some reason, I go Scripts > Draw > Fill Quad Mesh
like you did in the video with the Fox, and it keeps giving me an error to check all the points.
I know all points are connected because I can paint/bucket fill them.
If anyone wants to take a look I would appreciate it.
File link: https://drive.google.com/file/d/1Vx5-Ay ... sp=sharing
FloridaJo
Post by FloridaJo »
Even if I start a new file, make a square it won't even register that as a quad.
If you remove the existing shapes, along the edges, you will be able to use fill quad mesh.
FloridaJo
Post by FloridaJo »
Sorry, I don't understand.
FloridaJo
Post by FloridaJo »
Here is a vid showing making one single quad and it failing.
https://youtu.be/xsrGH-cyWqU
You need to disable auto-stroke, if you're using the add point tool for this. Otherwise, delete the black outline by selecting it with the select shape tool.
Than you can use fill quad mesh.
FloridaJo
Post by FloridaJo »
synthsin75 wrote: Sat May 07, 2022 7:27 pm You need to disable auto-stroke, if you're using the add point tool for this. Otherwise, delete the black outline by selecting it with the select shape tool.
Okayyyyyy. Yipeee, that was it.
Thanks synthsin75
