Hi
when dimensions are separated , moho doesn't add position keyframe when click on layer on viewport.
add key for position of layer - moho 13.5.3
- davoodice2
Re: add key for position of layer - moho 13.5.3
If the channel is showing in the timeline, you can double-click it at the frame you want to add a keyframe.
But with dimensions separated, Moho assumes you don't want to accidentally keyframe them all.
- davoodice2
Thank yousynthsin75 wrote: ↑Sun Apr 10, 2022 10:01 am If the channel is showing in the timeline, you can double-click it at the frame you want to add a keyframe.
- Víctor Paredes
You can also hold Shift and drag to be sure to only add keyframes on X or Y (depending if you drag horizontally or vertically).
If you hold Alt, it will only add keys on Z.
- davoodice2
Thanks Victor. I modified the script and it sets key now.Víctor Paredes wrote: ↑Mon Apr 11, 2022 6:41 am You can also hold Shift and drag to be sure to only add keyframes on X or Y (depending if you drag horizontally or vertically).
