13.5.2 Problem Selecting Points
drumlug13
Post by drumlug13 »
I'm getting a strange point selection offsetting problem when I'm trying to work on Actions. I couldn't get a good screenshot of point selection because the highlight on the point disappears when I let go of the mouse. But I did notice this same weird offset going on with the curvature tool too. You can see that the Bezier handles are way to the left for some reason. So to move points around with the Transform Points tool, I have to guess where to click, and even then it's real hit and miss.
Point selection seems to work just fine outside the Actions menu
So far I have relaunched Moho, reset my PC (WIN X), and then finally I just uninstalled and re-installed. Still no fix... Any ideas?
Adam
Re: 13.5.2 Problem Selecting Points
Without seeing a file, my only guess is you may be using Windows display scaling. That has causes mouse offset for some, but not isolated to actions.
Yeah, if it's not already set to 100% or 200%, try that. I think the offset problem occurs when Windows is set to one of the 'in-between' values like 150%.
If you don't know where this setting is, r-click the desktop and select Display Settings, and then choose the setting from under Scale and Layout.
drumlug13
Post by drumlug13 »
If you guys have a minute to check the file out. I found the advanced scaling options in Windows, but it says that if I change it ( doesn't say what it's default it is) it says it may be hard to revert back to original settings. And I never know whether or not to trust a MS Win warning. But if it works on a different computer I can change it here
https://www.dropbox.com/s/4ypl458sf8jt4 ... .moho?dl=0
Adam
chucky
Post by chucky »
Yeah that's definitely messed up Adam
Here's the culprit and workaround.
Mute the camera animation ( zoom) channel.
All will be fine.
This should be tested more I guess, it shouldn't happen.
drumlug13
Post by drumlug13 »
How do you guys know this stuff?! Thanks Chucky
Adam
chucky
Post by chucky »
drumlug13 wrote: Mon Mar 14, 2022 7:42 am How do you guys know this stuff?! Thanks Chucky
Well, I didn't know at all.
However, it was a question of screen space and cursor position.
So what in the file has any effect on that? The camera, so the answer was there.
I muted it, it fixed it, simples.
I'll report it. 8)
