fIKLock not reacting to setting fPos without a keyframe
Working on my version of the bone master scripts and I can't figure this one out...
The angles and position values are changed in the controlled bone layers. No key frames are created.
If I try to set the fIKLock value... the bones don't behave the way they would if the lock is set using key frames on the position without the script.
I am going for something very simple... just copying the lock from the master bone to frame 0 of the controlled bone for now.
I would be willing to copy keyframes in the same way that 7feet's switchslave script does... but it is over my head... at the moment. Copying keys from bone channels is not as simple as switches. Probably figure it out eventually... but want to know if there is some other reason why the bone lock setting doesn't force those bones to behave as locked using the current bone master script.
-Vern
