Where is Bind Points for Vitruvian Bones?
FloridaJo
Post by FloridaJo »
I'm going through the Vitruvian Bones in the manual, and it says:
"After you use that menu, you can still Bind points "
But 'Bind Points" is greyed out and not available.
What procedure am I doing wrong?
(see pic)
Re: Where is Bind Points for Vitruvian Bones?
It looks like instead of using the 'Use selected bones for flexi-binding', you bound the entire layer to the red bone in your screenshot.
If an entire layer/group is bound to a single bone, then you can't bind specific points.
To fix it, select the vector layer and go to Bone -> Reset all bone rigging
That will free the layer from that single bone. Now, to link the vector layer to the vitruvian bones' chain, select one or more bones from it and go to Bone -> Use selected bones for flexi-binding'.
I hope this helps!
FloridaJo
Post by FloridaJo »
So sorry Victor, you are right. I just found out I accidentally hit bind layer first, and "Bind Points" layer greys out then.
Thanks
No problem! I'm happy it worked for you :)
