I Opened one of my scenes. moho frame rate dropped to 1 fps.
no problem is 13.5.1 13 12.5. frame rate is 16
I deleted all keyframe and all psds. The problem could not be solved.
after lots of debug scene i found problem. reference layer!
I removed that and create again. problem exist.
I removed that and create duplicate. problem solved.
Some thing is wrong in moho 13.5.2
- davoodice2
Re: Some thing is wrong in moho 13.5.2
That seems wrong. I haven't used a Reference layer in a while...does this happen in 13.5.2 whenever a Ref layer is created or only in this particular project?
I'll try here later today if I have time.
I started making tests here to try to help. The rig I'm working on, after being referenced has the same performance impact on 12.5 and 13.5.2.
But then I read your post again and notice you are using psd. I have a feeling that the problem may be related to the new Moho-Photoshop synchronization capabilities. In the latest webinar Victor talked about how unfriendly and tricky photoshop system is and how hard it was to get the synchronization working. It may have problems with referencing.
I haven't tried the feature but maybe you can try some workarround looking at how it works: https://youtu.be/OMTZ-27dGeU?t=742
- davoodice2
not for all things. just for specific layer problem appear! .maybe for rigged psd layer. I must test more later.
I think I missed that webinar. Thanks for sharing the link.
