Use load command
davoodice2
Use load command
Post by davoodice2 »
Hello friends
Can i do this?
Local a= "mouseEvent.shiftKey"
If(a) then
End
I find some thing like load command in lua so
If(load(a)) then
End
But this didnt work
Re: Use load command
mouseEvent.shiftKey is a boolean...
so if you want to check if the shift key is down it's
if mouseEvent.shiftKey then
-- code if shift is pressed
else
-- code if not shift
end
davoodice2
hayasidist wrote: Tue Nov 16, 2021 12:11 am mouseEvent.shiftKey is a boolean...
else
end
thanks
NO my goal isn't check shift key. I want change shift to alt for example and it applie to all script. actually i want store mouseEvent.shiftkey into variable,and i change variable instead of mouseEvent.shift
Well, you could do mouseEvent.shiftKey = mouseEvent.altKey, but then you'd lose access to the shift key.
I don't understand what you're trying to do.
davoodice2 wrote: Tue Nov 16, 2021 12:59 am NO my goal isn't check shift key. I want change shift to alt for example and it applie to all script. actually i want store mouseEvent.shiftkey into variable,and i change variable instead of mouseEvent.shift
you mean you want all scripts - including "factory" ones to react as though (e.g.) shift was pressed when the user actually pressed alt ???
hayasidist wrote: Tue Nov 16, 2021 11:29 am you mean you want all scripts - including "factory" ones to react as though (e.g.) shift was pressed when the user actually pressed alt ???
If so, that would sound like a use for AutoHotkey, if on Windows.
