Moho 13.5.2 add to exporter not working (SOLVED)
opeth
Post by opeth »
Hi guys,
I tried many files but the result is the same . Exporter not working for me. Is it the same with you?
Moho 14.2 MacBook Pro 16'2 M1 Max 32gb.
Re: Moho 13.5.2 add to exporter not working
What is it doing (or not doing) exactly? Which OS?
FWIW, Moho Exporter is working here (Win 10) as it always has. (I prefer Moho Exporter over Export Animation for several reasons described elsewhere in these forums.)
When you launch Moho Exporter (ctrl-B) it should automatically add the current open projects. (I think the projects will need to be saved first.) If there are no projects listed in Moho Exporter, click the + button and navigate to the project you wish to add. If you have a batch of projects (i.e., Layer Comps) that you keep rendering again and again with the same custom settings and paths, you can save a Profile file and load that each time you render to save time.
If this is not working on your system as described, I'm not sure what could be wrong. Does it work after rebooting your computer?
davoodice2
Post by davoodice2 »
opeth wrote: Wed Nov 10, 2021 4:19 am Hi guys,
I checked. no problem for me.
opeth
Post by opeth »
Sorry guys i solved. When i upgrade Moho 13.5.2 . Export animation setting automatically choosed ' image sequence - PNG ' . I changed setting ' Video - Mp4 '' its solved.
Thank you for your reply.
