hi
any body can help please?
what is secondary selection?
- davoodice2
Re: what is secondary selection?
It's when you use ctrl or shift to select more than one layer at a time. There's the current layer, moho.layer, which is the last layer selected, and every other selected layer will return true for secondary selection.
- davoodice2
thankssynthsin75 wrote: ↑Tue Nov 02, 2021 1:55 pm It's when you use ctrl or shift to select more than one layer at a time. There's the current layer, moho.layer, which is the last layer selected, and every other selected layer will return true for secondary selection.
how I get second or and every other selected layer ?
Scan through the whole document checking for secondary selection, as per: https://mohoscripting.com/snippets/1
- davoodice2
thank you so muchsynthsin75 wrote: ↑Tue Nov 02, 2021 6:19 pmScan through the whole document checking for secondary selection, as per: https://mohoscripting.com/snippets/1
