preview animation
davoodice2
preview animation
Post by davoodice2 »
when I mark time line with ctrl+right click and left click and maximize viewport with alt+1 , markers be removed and moho makes preview from start to end.
and is there away to make better quality with preview animation?
Re: preview animation
Interesting. I never use Alt-1 because I prefer to keep the timeline visible at all times, but I just tried this shortcut and it happens here too. I'm sure this is a bug...will report it.
Re: preview animation quality: unfortunately, no. Preview animation tends to default to half-res, which I think depends on your current screen resolution and render resolution setting. For me, this hasn't been a big deal because I only use this feature to check quickly my timing when working with more complicated setups. I think it's only been a problem when I'm asked to render a higher quality preview animation at work for demo purposes. In this case, I use a screen video capture program.
I asked about improving the preview animation quality several years ago and it was discussed for a while. Hopefully, this feature will be improved in a future release.
davoodice2
Greenlaw wrote: ↑Mon Nov 01, 2021 11:56 pm Interesting. I never use Alt-1 because I prefer to keep the timeline visible at all times, but I just tried this shortcut and it happens here too. I'm sure this is a bug...will report it.
Re: preview animation quality: unfortunately, no. Preview animation tends to default to half-res, which I think depends on your current screen resolution and render resolution setting. For me, this hasn't been a big deal because I only use this feature to check quickly my timing when working with more complicated setups. I think it's only been a problem when I'm asked to render a preview animation at work for demo purposes. In this case, I use a screen video capture program.
thanks @GreenLaw .screen capture is good tip :D
davoodice2
Hauge improves in 13.5.2
Yes! :D
