THIS ISSUE HAS BEEN RESOLVED.
Hello. I upgraded to Windows 11 and installed Moho Pro. It worked on this system before but now reports that it cannot continue because MSVCR100.DLL is not installed. Any thoughts?
Moho 13.51 will not start under Windows 11
- iamthecrave
Re: Moho 13.51 will not start under Windows 11
- iamthecrave
Thank you! That is not the correct file, though. I need MSVCR100.dll ... with an R.
The advice is the same for either dll.
- davoodice2
download and install ' vc redist 'all versionsiamthecrave wrote: ↑Sat Oct 30, 2021 11:59 am Hello. I upgraded to Windows 11 and installed Moho Pro. It worked on this system before but now reports that it cannot continue because MSVCR100.DLL is not installed. Any thoughts?
I already use moho under windows 11
- iamthecrave
Hello and thank you. These kind suggestions did not work unfortunately.
1. MSVRT100.dll This changed the error message from "file missing" to "will not run"
2. VC Redist - Install all supported version (2021 - 2012) of 64 bit and latest version of 32 bit. This did not fix the problem.
- davoodice2
install from 2005iamthecrave wrote: ↑Sun Oct 31, 2021 9:06 am Hello and thank you. These kind suggestions did not work unfortunately.
- iamthecrave
Hello all. Thanks again for the suggestions. This worked:
1. Installed a copy of msvcr100.dll from another computer from System32 to System32.
2. Installed a different copy of msvcr100.dll from another computer from SysWOW64 to SysWOW64
Not sure which one did the trick, but likely just the first one. The other version of msvcr100.dll I downloaded from the link was half the size of either of the ones I found. The ones that worked were
System32 810kb
SysWOW64 756kb
System32 810kb
SysWOW64 756kb
