DV Transform Layer 9.5
davoodice2
Post by davoodice2 »
this is modified version of lm_transform_layer_Modified !
v9.4
fix scale bug.
add lock for scale axis
add Rotation X Y Axis
v9.5
change gizmo to standard industry like photoshop. (inside move - outside rotate ) away from gizmo don't do anything
fix bounding box
ability show create rectangle around all alayers
press up arrow key for select parent layer
https://www.mediafire.com/file/o16pfztu ... 4.zip/file
9.5 download
https://www.mediafire.com/file/v725156m ... r.zip/file
Re: Lock Scale Axis for layar transform tool
This is pretty cool, Davoodice2! I've wanted to be able to lock the proportions for some time. Access to other options like Opacity and Blur is nice too.
davoodice2
Re: DV_Layer_Transform 9.4
davoodice2 wrote: Sat Oct 23, 2021 7:24 am
fix scale bug.
Rotate X example.
davoodice2
Greenlaw wrote: Sat Oct 23, 2021 12:41 pm This is pretty cool, Davoodice2! I've wanted to be able to lock the proportions for some time. Access to other options like Opacity and Blur is nice too.
thanks. opacity and visible is done by others.
Re: DV Transform Layer 9.5
That link to v9.5 doesn't lead to the script.
davoodice2
synthsin75 wrote: Thu Dec 16, 2021 1:43 pm That link to v9.5 doesn't lead to the script.
thank you. I fixed that.
davoodice2
I forgot to write
