Gif with transparent background
peng
Post by peng »
Hi Moho Experts,
I am using moho 13. When i render animated gif, how do i make the background transparent? and sometimes some colors will automatically becomes transparent for no reason. Please help :)
Cheers
Peng
Re: Gif with transparent background
Assuming you have some transparent regions in your Moho project, you need to pick a frame that shows all your colors, Ctrl+R to render that frame, and hit the Sample Gif Colors button. Then when you render the gif, you select Transparency in the Animated Gif Options, and select enough colors to cover the number of colors (including in gradients) used. Not sampling gif colors or allowing enough colors can lead to missing colors.
peng
Post by peng »
wow! thank you so much, this problem has been bordering me for a long time. Thank you thank you!
