Play Audio in Both Sides
Gaucho
Post by Gaucho »
Hi Everyone!
After importing an audio track (wav or tiff) in Moho Pro 12.5.1 in Mac, the voice plays only in left channel, not center where I want it. The original source file plays in the center. This is still happening when spatial positioning is off (or on), as well with inmune to camera is on or off.
Any solution would be appreciated!
Thank you!
Re: Play Audio in Both Sides
Make sure Spatial Positioning is disabled in the audio layer's audio settings.
You can also make new audio layers disable this by default, with the script I posted here: https://www.lostmarble.com/forum/viewto ... 61#p196061
Gaucho
Post by Gaucho »
synthsin75 wrote: ↑Sun Oct 17, 2021 12:36 pm Make sure Spatial Positioning is disabled in the audio layer's audio settings.
Thank you Synthsin75 for the script.
After installing it this is the message that showed on the screen,
…audio/Documents/Moho-Pro/scripts/tool/syn_no_spatial.lua:1: syntax error near char(209)
and although the disabled mode appears as a default, the audio is still coming out from one side only (speakers are working fine with other applications).
Hope it can be solved some how!
Cheers!
Gaucho wrote: ↑Sun Oct 17, 2021 1:04 pm After installing it this is the message that showed on the screen,
I'm not sure how you saved it as a single line, but I don't see that error in 12.5 on PC.
Can you post an example audio file with the problem?
Gaucho
Post by Gaucho »
synthsin75 wrote: ↑Sun Oct 17, 2021 3:07 pm
I think that the working file became affected somehow when saving it. I went back to the source file and it seems to play okay now in Moho.
Thank you anyway for taking the time to help!
