find clicked menu
davoodice2
find clicked menu
Post by davoodice2 »
hi.
in bone select pop up dialog how to find witch menu is clicked?
for these menus
target
angle control bone
position control bone
scale control bone
if target menu clicked do something
but if position control menu clicked do something other
I work on im_select_bone
Re: find clicked menu
davoodice2 wrote: Sun Sep 05, 2021 12:54 am in bone select pop up dialog how to find witch menu is clicked?
The UI is built from various base widgets e.g. TextControl https://mohoscripting.com/methods/395 and in each there's a reference to "msg" - and that's what's sent to HandleMessage(moho, view, msg) (see https://mohoscripting.com/script_structure). Convention demands use of message numbers as some positive offset from MOHO.MSG_BASE
to answer your specific question about select bone: take a look the code (C:\Program Files\Moho\Resources\Support\Scripts\Tool\lm_select_bone.lua)
Since a popup menu itself doesn't send a message, just clicking on one cannot be detected. You can only detect when one of it's options has been selected.
davoodice2
synthsin75 wrote: Sun Sep 05, 2021 3:15 am Since a popup menu itself doesn't send a message, just clicking on one cannot be detected. You can only detect when one of it's options has been selected.
its true. but I detect that by change msg for each menu when MOHO.BuildBoneChoiceMenu
davoodice2 wrote: Sun Sep 05, 2021 4:06 am
Cool, you solved your own problem.
